Old 4-Nov-2016, 6:56 PM   #2
Hello, Alex:
All the networks you want are available from the ESE.
The trees in the signal path are a wild card. Try a Winegard HD7694P antenna without a preamp, with just one TV. Then, add the splitter. If the signals become too weak, replace the passive splitter with a CM3414 distribution amp.
If you have a problem with WTVD ABC on real channel 11, you might have FM interference.
http://www.fmfool.com/modeling/tmp/e...d/Radar-FM.png
