[QUOTE=rabbit73;56722]Yes, ADTech is correct; difficult, but not impossible.
I went to rabbitears.info and entered my estimate of your address. If you click on the callsign there, you will see the networks. The callsigns will be listed in virtual channel number order, not strength as in a tvfool report.
does that mean I point the antenna south at 191 degrees to get channnel 9?
