Would you recommend sticking with the antenna I have and getting a "pre-amp" ?
Which one would you get?
Is there a difference between a pre-amp and regular amp or is it all the same? Also, I noticed that antennas direct made an amp called a juice, could using the pre-amp increase my chances at picking up that station I want, or is it more about pointing?
