I think the antenna with the tilt made the most difference because my signal is much stronger and consistent. The new cable made a difference in my signal to noise ratio. I was getting varying readings with my SNR after a couple days with the new antenna. Some times it would be stable SNR and others it would fluctuate. So I decided to do some basic troubleshooting like taking a splitter out of the equation between the wall plate and the pre-amp. I figured I might as well make a new cable since I have the extra cable and who knows the quality of cable HDHomerun packages with their tuners.
