Old 31-Oct-2016, 5:03 PM   #35
agmccall
OK so I took the summer off from trying to get channels and finally decided to see if I could improve my situation. To recap, based on recommendations from here I installed the following winegard hd7698p antenna and Channel Master CM-7777 Titan 2 Antenna Preamplifier. Then I was unable to get any stations so it was suggested that I remove the pre-amp I did this and now I get the following
06-1 6.3 WRGB-HD CBS "CBS 6"
06-2 6.4 this TV This TV
06-3 6.5 Comet Comet TV
10-1 26.3 WTEN-HD ABC "WTEN"
10-2 26.4 WTEN-SD GetTV
10-3 26.5 LWN Justice Network
13-1 WNYT-HD
13-2 WNYT-ME
13-3 WNYT-WX
I also still get 2-1,2-2,2-3, and 2-4 out of utica NY.
But, I do not get 17-1, 17-2, and 17-3 out of Schenectady which is between my home and Albany, these are the PBS stations Also, 23-1, 23-2, 23-3 which is FOX, Horse Racing and Laff. I do not really care about horse racing or laff but I would like to get FOX.
It was suggested that I get another pre-amp that is not as powerful as the Channel Master CM7777. The only issue is I need a powered splitter to distribute the signal in the house because All the cable lines come together in the basement and the runs are anywhere from 25-50 ft.
Any further suggestions and/or ideas would be greatly appreciated
Thanks
Al
agmccall is offline   Reply With Quote
