I agree, but the problem is, we don't have a basement. Outside the house, there is only one place where Comcast's internet comes from. The wire is buried until it reaches the side of the garage, where it connects to some box and that box's wire (I can see from inside of the garage's roof) that the wire just goes to the attic directly.
Follow the wire that goes from "some box... to the attic directory". See if you can find out where it goes - probably to a splitter. Disconnect that wire from the splitter and instead connect a new cable that comes directly from the new antenna.
You many need to try the antenna in several locations in the attic before finding a sweet spot. Use a long enough cable to allow that.
