Old 29-Oct-2016, 7:49 PM   #4
Jake V
Make sure to disconnect the cable from the cable company wire that goes to the outside. You should be able to draw a path from the antenna to each of the televisions.
You can probably find some cheaper options, but it's always an experiment. I've used Antennas Direct products in several installations and am impressed with their quality. Other companies also make good products. You certainly can shop around.
