Old 22-Oct-2016, 2:38 AM   #18
If you want to experiment with another antenna for WFSB, I suggest the Antennas Direct 91XG or the Solid Signal HDB91X. They both have a tilt feature that allows you to tilt the front of the antenna up to capture the signal coming down from the crest of a hill. I have received several reports that it made reception possible, which otherwise was impossible.
