Originally Posted by rabbit73
Please do a tvfool report, using exact address or coordinates of the location of your antenna. Your exact address will not show in the report and any coordinates will be shortened. With an active link to your signal report, we can click on a callsign to see the terrain profile between the transmitter and your location.
Here you go ->
http://www.tvfool.com/?option=com_wr...d6dbf19cecb97a
Note that a good number of the stations that the report says SHOULD be receivable are NOT (especially those from NYC and Albany). As I indicated, East is the only direction that I get decent signals from. Too many mountains to the south and north. I've even tuned in some Boston stations a couple of times this summer. I always though ducting was a VHF only phenomena!
If I point the UHF antenna to the North, I can just barely receive Ch 22 out of Woodstock. But then I loose everything else. I also thought about adding a rotor, but it looks like most of the decent rotor manufacturers have gone away...
What make and models?
What make and model? I am interested in FSMs and signal level meters (SLMs), and enjoy making measurements as you might notice in my signature.
UHF antenna ->
http://www.solidsignal.com/pview.asp?p=hdb8x
VHF Hi Antenna ->
http://www.mcmelectronics.com/produc...-2475-/30-2475
PreAmp ->
http://www.solidsignal.com/pview.asp?p=tvpramp1r
The F.S.M. is a Channel Master Model 7275 leftover from my younger days (40+ years ago) as an MATV/CATV tech.
The antenna was moved to another location, and the signal was picked up during a scan and could be decoded:
I don't have a lot of property, or a large house. I did some measurements before selecting the mast location. Where the mast is right now is probably the best overall signals for the 4 reliable channels. There WAS another location on the roof that was slightly better, but WAY too close to the AC service entrance for my comfort.
Thanx for the reply.
Richard Rosa
