A few questions...
What type of home do you live in? Apartment or single family? Single story or multistory?
Where in the home is the antenna located? On inside wall, basement, upper floor? What side of the bulding, N, E, S, W?
What type of construction is used in your home? In particular, is there metal used in the siding material, stucco with reinforcing wire mesh, framing, roofing or insulation?
What sort of buildings and landscaping are near your home?
Have the antennas you have tried needed power, AC or battery? Have any of the antennas been rated by the manufacturer to receive VHF channels? If so, what is the model number of the antenna? The stations, FOX and ABC, are broadcast on VHF channels 11 and 7.
Thanks...
