Old 17-Oct-2016, 10:58 PM   #3
I think inserting a HLSJ (high and common ports) between the antenna and the input of the amp is a good idea, but that one is discontinued. Try this one:
You DO have some strong FM signals that might interfere with the reception of KELO CBS and KSFY ABC. I did this FM signal report based on an estimate of your location from your tvfool report which was only resolved to block level:
http://www.fmfool.com/modeling/tmp/5...e/Radar-FM.png
You can do a more accurate FM report here:
I see a lot of trees in your area; trees block TV signals. Do you have any trees or other buildings in the signal path from 164 degrees magnetic?
Scroll down to Trees and UHF
Grounding the coax with a grounding block will reduce the chance of interference.
I am wondering if an antenna amplifier on the antenna itself will help me out??
Maybe, but it might be overloaded by K50DG. And you certainly don't need a preamp AND the GE 24 dB amp. Try the HLSJ as an FM filter first.
Your two problem channels are on VHF-High, (real channels 7-13) but your GE antenna doesn't have much gain on that band.
The antenna indicates 70 mile reception area on the box.
We don't take mileage figures for antennas seriously, they are just marketing terms. We go by the signal strength on the report. What good is a 70-mile antenna if you have a hill 5 miles away in the path of the signal?
