Old 17-Oct-2016, 8:00 PM   #2
welkin
Installing an HLSJ will block all frequencies (including the FM band) below VHF HI. I don't know if you plan to use your antenna for FM. Also, it would block KDLO CBS if you are receiving it on the backside of your antenna. Go Jackrabbits!
http://www.solidsignal.com/pview.asp?p=hlsj
welkin is offline   Reply With Quote
