Old 15-Oct-2016, 1:30 PM   #15
Rabbit, I went back to the post I did back in Hi Def. I'm sharing it because we had covered this problem
Ah, yes; I forgot about that. We did cover it fairly well.
I just bought a Vizio 70" 4K TV
Which model, M70-C3 or P702ui-B3 or E700i-B3 or something else?
When you bought the Vizio 70" 4K TV without a tuner, your problem got even more complicated. You could have two external tuners, one for each antenna system. The output of one tuner would connect to the HDMI input of the 4K Vizio, and the output of the other tuner would connect to the component input of the Vizio. Alternative: 2 HDMI inputs on the Vizio. You would switch inputs of the Vizio to switch antenna systems if the Vizio would allow that to work.
