Thread: antenna upgrade
Old 13-Oct-2016, 9:28 PM   #2
ta240
After more reading I'm actually wondering if I'm going the wrong way with trying for a stronger signal. Maybe I'm still getting too much even with the lower power pre-amp.
Since the channels that have problems always have them after dark when the signals should be stronger with less noise are they just crossing the limit of being too strong at that point?
I may not be able to do anything about channel 9 since the other channel 9 would get stronger after dark too and that is already a directional antenna.
Should I try adding an adjustable attenuator? and back the signal off a bit
ta240 is offline   Reply With Quote
