13-Oct-2016, 1:19 PM
#7
Antenna Enthusiast
The 3-4 two tuner box
I found this from back in 2012 in this forum:
http://forum.tvfool.com/showthread.php?t=2882
8-Mar-2012, 8:55 PM
* #3
ghz24
2 Channels
Most of the tuner boxes have a switch to select between channel 3 or 4 for the boxes output, so you could put one box on 3 and another on 4 and combine the signals with a splitter/combiner into one coax to the TV.
The boxes I use have RCA out as well and their remote "input" button cycles through channel 3 ,4, RCA 1 and RCA 2 on my TV.
This gives me room for 3 separate antennas/tuners selectable from the remote (my dvd uses one set of the TVs RCA inputs)
I went to this partly because even an A/B switch before the tuner kills my weakest signals.
Even leaving off the RCA for the oldest TVs One could combine 4 antennas with 4 tuner boxes, 2 combiners, and one A/B switch just before the TV.
Would this work for me? I mean the CH3 / 4 two tuner box solution?
