The antennas Direct 91XG with a channel master 7777amp I say that you should give it a try you might be surprised on what you receive and I suggested that the Antenna be 10Ft high OFF the roofs line AND a A G L of 30,and don't FOR GET to ground the antenna and use a good RG6 CABLE 18Gage solid copper not copper clad steel Cable for best performances in receiveing channels good luck and be safe on the roof
