Old 5-Oct-2016, 11:35 PM   #7
I did find the following by GroundUrMast that I think looks very promising and along the lines of what I was considering...
Yes, that looks like a good solution for you.
Mount a Winegard HD7694P antenna aimed at 210 degrees magnetic, and connect it to the antenna input of your TV for your local channels, Fox and ABC.
Aim your DB8 at 185 degrees magnetic for NBC and CBS. Connect it to an external tuner, with its output connected to the aux input of the TV.
