Old 4-Oct-2016, 5:03 PM   #31
Blackbeen
It's not a factor at this point since I recabled to a separate rotor connection but a FYI to anyone who might want to attempt a single cable connection with the ROTR100 from ProBrand support: " Channel Master Spartan series Pre Amps draw less current so 0068DSB, 0268DSB are good ones and 0065DBS and 0265DSB come without the power supply so may be a cost saving as well.. I am not sure if they still have these lower voltage, lower current draw units but that is where to check."
I also contacted WMYD & they verified that there have been no changes on their end so at this point I have conclude that the loss of DB4e from the stack or the combiner are the cause, not a lot of time to verify this in the next couple weeks.
Blackbeen is offline   Reply With Quote
