If you get WHPX ION with your Clearstream CSM-1 and Winegard LNA-200 amplifier, but not WTIC, try a "brute force" approach with an Antennas Direct DB4e and a CM7777 preamp, but it's a gamble. There are other 4-bay antennas, but the DB4e is safer to handle indoors.
If WHPX, real channel 26, overloads the 7777, insert a ChannelPlus Model NF-471 RF Notch Filter between the antenna and the preamp input.
NF-471: Notch Filter
Removes CATV channels 75-80 and UHF channels 24-29
Notch filter frequency 529.25 MHz to 559.25 MHz
24 530-536 MHz
25 536-542
26 542-548
27 548-554
28 554-560
29 560-566
