Old 27-Jan-2011, 8:39 PM   #4
I would try the HBU-33 'barefoot'. It has 7 dB of gain which puts you over the top with enough signal to split later on... If in the future, you find you need gain to make up for cable and splitter loss, you can add a preamp. If you did, I would play it safe with a modest gain, high input design such as the Winegard HDP-269. Driving one receiver you should not need it though.
