Old 3-Oct-2016, 3:26 PM   #18
k man
Installer finished
So the installer came out and I ended up with a digitenna dt-xf amp20-1. Preamp mounted on mast, power injector in garage. Its pointed east north east- about 42 degrees. Trying to go south at first to get wtnh didn't work. WTNH showed a signal on the meter, but not on tv. the good news is he was able to get channel 40 and 22 from springfield which accomplished jeopardy and an abc affiliate in my lineup. The installer claims local stations are strong enough for signal to catch back of antenna, while pointing 42 degrees to capture springfield.
Installer did a great job plumbing wires and such, everything looks clean. He said he stands behind his work and would come back out to address any issues.
a couple of things here- 1. I now have a tivo, which is a 4 tuner box.
2. the other night during some mist/rain, channel 61 became pixelated?
3. would putting a small amp right in front of the tivo help?
k man is offline   Reply With Quote
