Old 3-Oct-2016, 12:49 AM   #5
RickD
Hi rabbit73 and ADTech,
Ok, rabbit73, I pointed the antenna directly at CBC and channel 9 came perfectly 'as well as all the north stations out of Detroit' !! Problem solved ? I guess! Thanks!
ADTech, very sorry I am antenna naive :-) noise margines and db I don't understand.
Regardless I think the problem is fixed and I thank both of you for your help!
Any idea why I couldn't pick up CBC from the back of the antenna and I can pick up all the Detroit stations from the back? Just curious.
Also if you think any other antenna would be better in my situation let me know as antennas are cheap. (even though I think I'm good now)
Thanks again!!
RickD is offline   Reply With Quote
