A simple line amp such as our variable (5-20 dB) unit should fix the problem. I used one in my home for a similar situation and it performed very well.
The Skywalker splitters appear to be of the unbalanced type. That means one output will be down about 4 dB, the other two will be down almost 7 dB. If you can figure out which is the -4 dB port, use it to feed the longer run (first splitter) and use the -7 dB ports for the first two TVs.
