Old 1-Oct-2016, 2:33 AM   #15
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Originally Posted by Blackbeen View Post
I tried to comb a number of the specific magnetic points (at least for 7 & 20), didn't seem to differ much.
I'm limited to a preamp designed for powering by +17 VDC at less than 50mA using a single cable connection in conjunction with the Eagle ROTR100 I'm not sure if that one will work, I'm presently using none, I have a Juice but its incompatible, I'm not sure which ones are, I wrote the company for suggestions.
I'm sorry I did not realize you were running a one wire rotor system. Personally, I would run a separate cable. If it were me, I would be trying it a different idea like some sort of pre amp system...I hope one of these other guys chimes in, maybe someone has a better idea...
I would like to see you succeed, I hope you can figure out what is wrong with your system. I guess possibly you could get a larger antenna like a DB8e for your UHF.
