Old 30-Sep-2016, 3:31 PM   #12
Blackbeen
It might be that the DB4e worked better because it is not as directional since it looks like you are trying to pick up channels from some degrees apart.
For about $14 more there is a RCA PREAMP1R available and it is a great UHF/VHF combiner. I used it to combine my UHF VHF antennas. it has about 20bd boost and lower noise. There were some issues reported a while back, but I haven't read anything lately and both of mine work well.
Anyhow, I hope one of the experts can offer some help here for you.
I tried to comb a number of the specific magnetic points (at least for 7 & 20), didn't seem to differ much.
I'm limited to a preamp designed for powering by +17 VDC at less than 50mA using a single cable connection in conjunction with the Eagle ROTR100 I'm not sure if that one will work, I'm presently using none, I have a Juice but its incompatible, I'm not sure which ones are, I wrote the company for suggestions.
Blackbeen is offline   Reply With Quote
