Old 29-Sep-2016, 2:14 PM   #4
Good luck with that... Combining dissimilar antennas aimed in different directions can most charitably be described as "potluck". You'll get what you get and that's what you'll get. Temper your expectations.
Any outdoor-rated two port splitter will suffice. Use quality compression fittings and it will be water-tight.
