If the disruption occurs at exactly the same time every day like clockwork, the problem is due to electrical interference from something on a timer (clock).
If the disruptions occur at, as near as you can tell, the same time relative to sundown, the problem is something on a dusk-to-dawn sensor.
No amplifier will cure either issue as the amp will only amplify the interference as well as the signal.
