Old 22-Sep-2016, 12:53 AM   #3
comfortably_numb
Welcome, comfortably_numb:
You should be receiving KMJC if it is on the air. Anyone else in your area having trouble receiving it?
What antenna and preamp are you using?
If it IS on the air, you must be having equipment trouble or something on N Holmes Rd is blocking the signal.
I don't know your exact address, but this is what I see:
You can do your own green lines here by moving the cursor (drag and drop) to the antenna location.
Have you tried another TV, another antenna, or another antenna location?
The only other thing I can think of is that the tvfool report is wrong and KMJC has a very directional transmitting antenna that sends very little signal in your direction.
http://www.rabbitears.info/tvq.php?r...s&facid=184373
http://www.rabbitears.info/contour.p...33%2C-94.98725
I have an RCA ANT751 pole mounted on my roof, and an RCA TVPRAMP1R preamp. I've aimed the antenna in the direction of the KMJC tower but can't receive anything. It's interesting to note, however, that I can receive KQTV in St. Joseph, MO (104 miles away) as well as KMOS (114 miles away) and all the local Kansas City stations with 100% signal strength. Last night, I was picking up stations in Springfield, MO (140 miles away) and Columbia, MO (163 miles away). So I guess KMJC is just REALLY low powered??
comfortably_numb is offline   Reply With Quote
