Line of sight and RCA antenna test fail
alright, I took Jake's advice, went to walmart, tried the rca 751. While I wasn't able to perform the test via rooftop, the ground level test failed to pick up wtnh and wggb.
regarding line of sight-(Tried to upload pictures here but could not), facing northeast (41 degrees) I have at least 150 yards of clear open space before a single line of trees come into play. I'd estimate those tree tops to be at a 5-10 degree upward angle.
Facing south (196 degrees), trees come into play at about 50 yards. Those tree tops are much higher and closer- tops are at 45 degree upward angle.
Given those two scenarios, what is my next step? Is my abc goose cooked?
