Old 20-Sep-2016, 5:03 PM   #9
Jake V
Nascarken,
The Winegard 7698P is certainly a good antenna, but it has a fairly narrow forward looking beamwidth (which helps with two edge signals in a single direction).
cjm has signals in at roughly 124 degrees and 337 degrees. Why do you believe that the 7698P would do better at receiving the signals from both these directions? It seems to me that the DB-4e (or any vertical 4-bay antenna) with the reflector removed would be more bi-directional?
Thanks in advance for sharing your reasoning on this question.
Maybe others can also post on this.
Jake
