Old 18-Sep-2016, 8:55 PM   #13
ngs428
Almost a year later, all channels are coming in aside from 33-1, 33-2 and 33-3, the FOX WZAW channels. They used to be 55-1, 55-2 and 55-3, but recently changed and are still broadcasting from the same location. They still broadcast with what seems to be low power and are not even on the TV Fool report. They broadcast out of a true 58 degrees while channel 27 broadcasts out of a true 166 degrees. Seems like it is too much separation for my clearstream 2V which has a 70 Degrees (Horizontal Plane) Reception Pattern. 33-1 since I added the CM3412 just pixelates every 30 seconds or so.
I currently have the following as a setup:
https://www.dropbox.com/s/udlyjahbtg...tenna.jpg?dl=0
I can also get Fox on 7-3, so this is not a big issue. 7.3 seems to not have as much bandwidth as 33-1.
Thoughts get 33-1 in better? Possibly a different antenna?
ngs428 is offline   Reply With Quote
