Old 18-Sep-2016, 12:45 PM   #2
Jake V
You have stations at roughly 124 degrees and 337 degrees. They are not near 180 degrees apart to use a bi-directional antenna but I think they might be close enough for an easy experiment.
I'd start by mounting an Antennas Direct DB-4e with the reflector removed (which makes it bi-directional) with the addition of the VHF kit. I'd probably aim the antenna at about 315 degrees on a compass (meaning the back side will face about 135 degrees). Both directions are within the about 60 degree range that this antenna can see.
But this is my opinion. Others more knowledgeable than I will comment.
