Old 27-Jan-2011, 3:52 PM   #1
txv11
Attic Antenna Help in Cleveland, OH
I am trying to "cut the cable" and have been tinkering with antennas in my attic.
My TV Fool Report can be found here:
http://www.tvfool.com/?option=com_wr...3cf4afd482d7b0
I created a 4 Bay Bowtie antenna and get results that I can't quite explain. My setup includes a 50' coax run to a 2 way splitter, which then goes into a Silicondust HDHomerun dual tuner. My roof is slate, no foil insulation. I can reliably get real channels 8, 15, and 17. Depending on where the antenna is pointed (with only slight variation) I can reliably get real channel 10 or 26, but typically not both. I'm most interested in receiving the channels 228 degrees to 231 degrees. If I could get the second PBS station at 191 degrees that would be nice, but I recognize it may not be possible.
I also recognize that being a DIY antenna it may not be optimal. But the results seem a little strange. I'm looking for a recommendation on an antenna that would allow me to reliably receive the channels I mentioned above.
Thanks.
txv11 is offline   Reply With Quote
