Old 17-Sep-2016, 5:51 PM   #3
I would like to receive.
KYTV 3.1 UHF
KSPR 19 UHF
KOZL 27.1 UHF
KOLR 10.1 VHF
KYTV 3.1 NBC, real channel 44, NM 13.5 dB, 63.7 mi, 331 deg mag
KSPR 19 ABC, NM 16.0 dB, 63.7 mi, 331 deg mag
KOZL 27.1 MyN, real channel 28, NM 13.0 dB, 66.6 mi, 332 deg mag
KOLR 10.1 CBS, real channel 10, NM 13.9 dB, 66.6 mi, 332 deg mag
Channels that far away will have interference to the signal from the curvature of the earth.
VHF-Low, real channels 2-6
VHF-High, real channels 7-13
UHF, real channels 14-51
Those 4 channels will require a Winegard HD7698P antenna aimed at 331 degrees magnetic.
The booster is a problem. I would suggest a CM7777, but it might be overloaded by K07XL, which is a low power station but only 1.1 mi away. A CM 7778 might be a better choice.
K41HC is off the air.
