Old 9-Sep-2016, 11:56 PM   #24
jerrymc
Hi Rabbit:
A couple years ago I had the RCA ANT751 antenna with the RCA TVPRAMP1R pre-amp. I had decent signals from Mt. Wilson, albeit many upper UHF stations barely came in.
I decided to get the larger antenna and better/stronger pre-amp and I do get many more stations from Los Angeles.
KVCR is not a station we watch. If that's the issue with all the other stations, can I block KVCR's signals? (91.9Mhz) AND The FM signals in that range?
(I cannot tell you how many times I climbed that steep roof just to tweak the antenna!)
I just received my LTE filters from the UK but I do not think this is the correct range here in the US.
(Frequency range : VHF 5 - 300MHz (400Mhz trap)
Frequency range : UHF 470 - 790MHz)
LTE TV Filter
Many Youtube videos I see regarding LTE and OTA TV interference are from Australia and Europe. I read that US LTE will soon be utilizing the 600Mhz range which seems to cut into many stations here in the So. CA area.
I am going to remove the 3410 dist. amp and try out the LTE filter this weekend. I already grounded the coax, but still need to purchase and ground a new shorter 18 galvanized pole.
Does the 7777 pre-amp have a sufficient FM trap?
I will study the reports you sent this evening and once again, thank you very much for your help!
HD8200XL and HDB91X with RCA TVPRAMP1R pre-amp aimed at Mt. Wilson (Los Angeles) in Etiwanda area.
CM3410 dist. amp in attic for a 5 room hookup.
Located in foothills behind Mt. Baldy, and experiencing signal loss and pixelation depending on time of day.
Using RCA rotator motor now to tweak.
Location Radar
jerrymc is offline   Reply With Quote
