Old 8-Sep-2016, 3:56 PM   #17
jerrymc
There is one experiment that might be worth trying. Insert a HLSJ, common and high ports, between the antenna and the input of the preamp. This will block signals below channel 7, including the FM band.
Even if your antenna is aimed away from KVCR, I still think it might be too much signal for a 7777, assuming your tvfool report is an accurate prediction of the signal strength arriving at your antenna.
Is the HLSJ the same as this combiner?
https://www.walmart.com/ip/Channel-P...2-Way/19622660
I need to properly ground everything because the only thing grounded currently is the coax and that's in a box on the side of the house where I have a splitter to send feeds to 2 rooms. (Leftovers from TWC)
The other splitter is in the attic for the other 3 rooms...
Once again thank you for your expertise Rabbit!
RABBIT
HD8200XL and HDB91X with RCA TVPRAMP1R pre-amp aimed at Mt. Wilson (Los Angeles) in Etiwanda area.
CM3410 dist. amp in attic for a 5 room hookup.
Located in foothills behind Mt. Baldy, and experiencing signal loss and pixelation depending on time of day.
Using RCA rotator motor now to tweak.
Location Radar
jerrymc is offline   Reply With Quote
