Old 8-Sep-2016, 11:42 AM   #1
Zee
Grounding antenna against lightning?
Hey guys,
I installed my antenna on the roof. There was nothing to mount it to so I stuck a fence pole into a concrete base and just placed it on the roof of my house, which is flat with a rubber membrane covering a plywood surface.
Is this now a magnet for lighting? Should I be running some kind of grounding wire from it to the water main?
Thanks
Zee is offline   Reply With Quote
