Old 6-Sep-2016, 6:45 PM   #26
rickbb
You won't be able to run the pole all the way into the ground due to the electrical panel being directly below the ridge line.
You could however use a chimney strap mount even though that's not a brick chimney it should still work.
Edit; unless that's vinyl siding, looks like it is. Scratch the chimney strap.
