Old 3-Sep-2016, 7:48 PM   #23
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Masting advice
Originally Posted by wado66 View Post
This is an actual picture of my home where I want to put the antenna just so you know what I am dealing with.
You can get the antenna up 30-42 feet AGL. So 2 21' sections of 1 5/8 or 1.66 as the hardware store calls it would get you up there I would use the thickest pipe available, or sleeve it -or both. Now you don't care what weighs because the load bearing is done by the ground hopefully on concrete with a folding base so you can tip it out. But that part, isn't necessary. The concrete part is important though.
And ground it.
Rabbit, who is the most helpful person and the most resourceful person on this and other forums gave you some great detailed photos. You are in good hands here !
