Old 31-Aug-2016, 11:37 PM   #8
jerrymc
Thanks for the interesting photos.
Do you get NBC and CBS?
It's a shame that you have to use an RCA DTA880 to tell you what the TV should tell you. I like the Diagnostics Screen on my Sony TVs that gives me signal strength, SNR and uncorrected errors.
I'm surprised that you can use a 7777 & a 3410 without tuner overload. I would have thought you would need a single channel bandstop filter to attenuate KVCR.
NBC and CBS come in very strong. 60~70%
KVCR is in the other direction, so the signal it very well even though I'm pointed away from it...
The RCA box is pretty good for $40, and I've tested the HD recording with old SATA hard drives and it's crystal clear. I just don't like leaving the power plugged into the HD 24/7. The box even has a program guide! Something my Vizio LED, Panasonic plasma, and Sceptre 4K TVs do not.
Well, I supposed I can climb in the attic and remove the 3410 again to test...
HD8200XL and HDB91X with RCA TVPRAMP1R pre-amp aimed at Mt. Wilson (Los Angeles) in Etiwanda area.
CM3410 dist. amp in attic for a 5 room hookup.
Located in foothills behind Mt. Baldy, and experiencing signal loss and pixelation depending on time of day.
Using RCA rotator motor now to tweak.
Location Radar
jerrymc is offline   Reply With Quote
