Thread: New to OTA
Old 31-Aug-2016, 3:48 PM   #3
wizwor
Originally Posted by tinkerer View Post
I am going to cut the cord and go OTA. I am looking for any help or recommendations.
My TV Fool report is located here http://www.tvfool.com/?option=com_wr...e2cb1cae9a850b
We are neighbors. I live in Danville.
I would like to get WMUR (real 9), WBZ (real 30), WFXT (real 31), WHDH (real 42), WLVI (real 41) and WBPX (real 32).
I have a HDB8X-NI antenna for the UHF channels and there is an old VHF/UHF antenna in the Attic pointed at 293 mag. I plan on mounting the UHF antenna on the roof where I located it in the TV Fool report pointed at 205 mag.
You can see the list of channels I receive here...
https://freetvforme.wordpress.com/my-network/#lineup
I receive all the channels you are trying to tune. I think you could receive WMTW in Portland, too. That is an ABC affiliate that carries a Heroes and Icons sub.
My antennas are in the attic. If you are going to put the UHF antenna on the roof, why not put the vhf antenna on the same mast? The HDB8X-NI is probably a good choice for UHF (I use a DB8e). You will be able to receive WMUR and WENH on just about any VHF antenna pointed in the general direction of either. (I can get WMUR and WENH or WENH and WMTW but not all three without moving my VHF antenna.)
I don't have any amps or splitters yet. I want to drive two TVs and a DVR. The UHF antenna is about 45 feet from the attic antenna. From there to the TVs and DVR will take about another 50 feet of cable.
I use an RCA TVPRAMP1R pre-amp to join VHF and UHF antennas. Then I amplify and distribute using a EDA-2800.
I have lots of trees that I can't get over. The spot I picked for the UHF antenna has the clearest shot, just east of a giant oak, open out about 150'.
Thanks for the Help.
I shoot through red pines -- ever green and ever swaying. You should be fine.
wizwor is offline   Reply With Quote
