Old 31-Aug-2016, 3:16 PM   #6
rickbb
Originally Posted by wado66 View Post
The antenna will be mounted on a 2 story house.
I plan on attaching it to the eave with this bracket.
If I mounted a 15ft pole to this and antenna on top you think I would be ok for sturdiness?
Sorry, but I'm a noob cutting the cable for the first time and a little nervous about setting this all up.
The antenna will be using would be a CM-2020 or CM-3020.
I think that setup would be fine, but 15ft would be about my max to go without using any guy wires. At 20' definitely use a guy wire system.
