Old 31-Aug-2016, 11:26 AM   #2
Jake V
I'd likely try an Antennas Direct C2V or an RCA ANT751 pointed at 45 degrees on a compass for the stations that direction. If that does not get ION then move the antenna from 45 degrees towards 10 degrees until you get the stations in that general direction.
It would work best on the existing satellite dish mount, provided it has a clear line of sight from the house facing east-northeast.
If you are trying the attic, it will depend on the roofing materials and other stuff up there. If you have a metal roof or aluminum siding it may not work. I recommend running the coax through the opening to your attic from the antenna to one TV as an experiment before mounting anything. Sometimes you need to try several locations and sometimes moving it a few inches makes all the difference.
