That tells me I need my antenna at least at 30ft, correct?
No, the vast majority of antenna users have signal paths that are not LOS.
Secondly, how do I read the image below?
Is my house on the left or right of the screenshot? What does the red, yellow and green mean?
Signal Analysis FAQs: http://www.tvfool.com/index.php?opti...d=57&Itemid=89
Your location is represented as the point in the lower right where the gray (ground) meets the color. The broadcast antenna is represented by the white point near the upper left of the image.
