Old 30-Aug-2016, 5:06 AM   #18
Lexpilot
Yes the plans for the antenna I used showed the spacing for the elements.
The vertical feed lines are .o41 stainless safety wire and are wrapped around the screws under a washer holding the elements to the wood. There should be no loss between the feed wires and elements.
I figured out the picture attachment issue, thanks for the replies.
Dan
Lexpilot is offline   Reply With Quote
