Old 29-Aug-2016, 9:06 PM   #4
Stereocraig
I have no doubt that the bracket itself is adequate, but I would be concerned w/ that 3/4" fascia board and whether it would be meaty enough on its own.
You could probably use some 2X4 backing strips inside the attic.
If you were real lucky, you may even hit a rafter, or truss.
Be sure to drill pilots for the lag bolts, because they're cheap and snap easily.
I'd also like to see as much distance as possible, between my upper and lower brackets, to minimize twist.
