Old 29-Aug-2016, 4:24 PM   #13
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Originally Posted by Tigerbangs View Post
A couple of questions: I noticed a rotator motor on the mast: is it still functional? Do you have the controller? You may want to sync up the rotator to facilitate aiming the antenna. It also appears that he can get the Milwaukee stations by rotating the antenna after the things that ADTech suggested have been tried.
Excellent questions.
I may have mentioned in the original post that the rotator doesn't work. The indoor part seem to work, the dial moves when turned, and the motor in the control unit moves and audibly sounds like mine at home. I pulled the cover off the bottom, all wires are intact. I wiggled the mast while the owner actuated the rotator control, nothing happened. He needs a new one. Maybe. I have a voltmeter but don't know what to look for. He could just need new 3 wire lead.
Milwaukee would be a bonus.
