Start with a new matching transformer (balun) and a new length of RG6 coax. At nearly 15 years of age, the odds are high that one or both have suffered water infiltration or corrosion.
Lowes now carries an inexpensive matching transformer (RCA brand), it appears to be identical to the one that Winegard is using on their production of RCA-branded antennas. It performs well, but the leads are very fragile and care is required to keep from breaking the wimpy spade lugs or wire leads.
BTW, is he re-using the coax from the satellite install? If so, were any sat-specific devices (multi-switch, diplexer, etc) removed first? Failure to do so is a common failure among sat-to-antenna transition projects. We get those calls all the time.
