Old 29-Aug-2016, 1:18 PM   #7
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Thumbs up Could he be picking up those 2 channels without an antenna?
Hi Wizwor,
Thanks for your input .
Originally Posted by wizwor View Post
The first thing I would do is get a compass out and make sure it is pointing in the right direction. The Dish guys may have moved it when they installed their hardware. Then I would run a commercially terminated piece of RG6 right from the antenna to a television and make sure the problem isn't with something between the antenna and the television.
You may be right about the RG-6, but I had disregarded that because he is at least getting some channels, but definitely important to see if that is the issue.
Could he be picking up those 2 channels without an antenna? The transmitter is 40+ miles away but on the tallest building in Chicago though.
The aiming of the antenna probably isn't the issue, because he sat in front of the TV while I moved the antenna and we talked over our cell phones.
The trees, also may force him to put a taller mast up and a larger antenna with a tip up adjustment. No decisions on that yet
