Old 29-Aug-2016, 11:26 AM   #8
Yes, C2V not cv2. The C2 is a UHF antenna and the "V" dipole kit adds the ability to receive strong VHF-High signals on real channels 7 to 13. It is possible to mount the dipole so that it can be aimed in a different direction than the UHF "figure 8" loops.
https://www.antennasdirect.com/store...tenna-Kit.html
https://www.antennasdirect.com/cmss_..._201402062.pdf
video
https://www.youtube.com/watch?v=9pKj3NKGzZg
There are 3 versions of the VHF KIT UHF/VHF combiner (diplexer)
http://www.avsforum.com/forum/25-hdt...l#post39074442
I quote ADTech
Gen I = An external private-labeled Holland UVSJ attached to lower part of the vertical reflector support.
Gen II = The diplixer was integrated into the central hub of the loop element. Two F-connectors on the rear of the loop. Short-lived version.
Gen III= Diplexer integrated into the modular clip-on VHF accessory housing.
I'm not sure what is the best way to add the FM filter. Maybe ADTech, who works for Antennas Direct and gives good advice here, can guide you.
It is also possible to use a HLSJ (high and common ports) as an FM filter. It blocks all signals below TV channel 7, including the FM band.
